Sponsored by: Kumho
Tractor steer? problem
Old Jan 29, 2006 | 09:02 AM
prometheius's Avatar
prometheius
I have an 86 E350 class B motorhome with 168,000. miles. I have replaced all shocks, added an extra leaf spring in rear, replaced king pins and bushings (professionally honed), ALL steering components except power steering pump and gear box (which I tightend), new tires properly inflated. Problem is that it still feels like it has tractor steer: wanders from side to side. It seems to be better than it was but it's still there. If problem is coming from gearbox is there a way to diagnose this without taking box apart to visually inspect backlash? Any ideas?
Old Jan 29, 2006 | 10:39 AM
oldhalftons's Avatar
oldhalftons
new ragjoint in it? how is the lower steering column bearing? did you replace both the I-beam and radius arm bushings?
It your allready tightening the box, its time to replace it.
Old Jan 29, 2006 | 08:06 PM
mustange70's Avatar
mustange70
What kind of tires do you have on it?
Old Jan 29, 2006 | 09:07 PM
wickymustang's Avatar
wickymustang
Have you aligned it recently?
