Suspension Problem??
Old Jan 28, 2006 | 10:27 PM
bks90F150's Avatar
bks90F150
Question Suspension Problem??
I have a 1990 F150 2wd. The back left end of my truck seems to sag a little bit. When I look at the truck from the back, it looks like the back end is leaning to the left. What's wierd is that my headlights are still aligned properly, so it seems like it has always been that way. You'd think that if the back left suspension started to sag that the headlights would go out of alignment. Does anyone know if this is normal? If not, what could I do to fix it?
Old Jan 28, 2006 | 10:59 PM
someday's Avatar
someday
check your suspension and bed mount bushings, tweaked frame, cracked leaf, age, uneven tire wear,etc...the shackles and hangers are known to rot away so check those extra carefully...for a 15 year old truck u r probably going to have to live with it
Old Jan 29, 2006 | 12:38 AM
bks90F150's Avatar
bks90F150
I have checked the suspension, but I'll give it another thorough look-over. I have seen other F150's with a similar problem. The leaf springs still work properly and there is nothing wrong with the shocks. I haven't noticed a difference in handleing or hauling stuff. I just wanted to know if it was a common problem.
Old Jan 29, 2006 | 10:59 AM
quicklook2's Avatar
quicklook2
you have a broken/rusted shackle.
Old Feb 21, 2006 | 05:17 PM
Rickdj's Avatar
Rickdj
Had a similar problem with my 1999 f150 lariat, back left was 1 1/2" lower than the right side, my mechanic took off the leaf spring and had it adjusted, hight is back to normal now.
