anyone having problems w/6 cd player?
Old Jan 28, 2006 | 10:04 PM
paul812's Avatar
paul812
i have in dash 6 cd changer (factory) on '05, and it acting strange, i just bought the truck 12/23. I think its a el cheapo. It wants to skip and do weird things on several cd's, only using slot 1. How do you get that plastic cover off? i think i'll put my Kenwood in there, and does Radio shack sell the plastic adaptor piece that will go back in, to look somewhat like the factory piece and fit nicely? (or anyone else) thanks!! paul
Old Jan 28, 2006 | 10:27 PM
ford390gashog's Avatar
ford390gashog
to get the cd player out you remove the front of the dash and unbolt the unit. are you using home made cd's? any with stick on labels?
Old Jan 28, 2006 | 11:04 PM
paul812's Avatar
paul812
thanks but how do you pop out the plastic trim piece? does it just snap in like most? i would guess a small screwdriver and force it out? i'm using some burned cd's but none w/paper labels...thanks paul
Old Jan 29, 2006 | 12:42 AM
guerrero101's Avatar
guerrero101
Pull starting from the bottom just above the ash tray. There should be three metal clips on the left and the right side of th bezel.
Old Jan 29, 2006 | 01:30 AM
vancityf150's Avatar
vancityf150
I would like to take my 6 cd out and drive over it with my 35's!!!!!! Awesome truck. but what a pain in the a*s cd player, my Kenwood 8017 is on the way, can not wait! I've had the same problems.
Old Jan 29, 2006 | 10:00 PM
timcpa's Avatar
timcpa
My CD is doing the same thing! I only use new quality CD's. It skips and acts funny. I have not had it replaced because the dealer said they would have to remove it and send it off to be repaired and I would be without the whole radio and everything until it comes back. No telling how long that will take. I was also worried about more rattles after it was removed and put back in.
Old Jan 29, 2006 | 11:44 PM
paul812's Avatar
paul812
i wonder if the single disk players are having this problem? and where would be a good place to buy the plastic adaptor trim peice if an aftermarket player is installed? or i wonder if you could get a factory premium single disk player?...paul
Old Jan 29, 2006 | 11:50 PM
ford390gashog
using a after market cd player is kind of a pain. the wiring is complicated. if the truck is under warranty just get a new 6 disc.
Old Jan 30, 2006 | 02:33 AM
Eric Landstrom's Avatar
Eric Landstrom
I've had no problems with CDs and mp3s I've burned playing in my 6 disk player.
Old Jan 30, 2006 | 06:34 AM
Steve91's Avatar
Steve91
Mine doesn't like to load discs, but once they are in there, they seem to work OK.
Old Jan 30, 2006 | 11:48 AM
KevinM's Avatar
KevinM
I have the 6 cd player, no problem for the last 2 years and 26K miles. It sounds to me some are having problems with self recorded CD's.
Old Feb 12, 2006 | 11:20 AM
neveragainaford's Avatar
neveragainaford
#8 & Counting
paul812:
I have had the 8th 6pak Audiophile component stereo put in my 04 Screw Lariat & it does'nt work any better than the last one or the orginal. The dash cover has been removed so many times it is loose fitting now. Everytime they were to change it the serial # had to be taken from the unit in dash so it has been off 15 times. Mechanic who changed out the last one told me after little asking that they (dealership) have changed hundreds and seem never to work any better than the one being replaced. Another of Fords better innovations. Quality and engineering are missing in most things North American. We should be like the Germans instead of trying to compete with the 3rd world build the product to best of our abilities and charge for the quality. I for one would pay for the better product.
Neveragainaford
