pinion seal
Old Jan 28, 2006 | 07:40 PM
Parthead's Avatar
Parthead
pinion seal
I have a 9.75 J1 rear axle on a '99 Expy that has just begun to sling oil behind the companion flange. Can I just replace the pinion seal without removing the pinion shaft from the housing?
Old Jan 29, 2006 | 07:34 PM
RTM's Avatar
RTM
You should replace the crush sleeve and reset the pinion bearing preload if it's to be done correctly.
Old Feb 5, 2006 | 11:59 AM
Parthead's Avatar
Parthead
I wanted to do the job myself but i don't have the impact tools to do it easily. I took it to the dealership for the cruise switch recall and talked to the tech. Turns out I had a bad transmission seal along with the bad pinion seal at the rear axel. Together it cost $300 to replace but I'm good to go now.
