Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Test Light
Old Jan 28, 2006 | 06:58 PM
bosshoss's Avatar
bosshoss
Post Test Light
Hey all.
I just bought a test light from Matco Tools, thats 6.12,24 volt able. It has a circut that tells if the wire your testing is a negitive or a positive or switches when something is aactivated. It has a 12 foot coil lead wire that is put on the battery of what your working on, then test your wires. A red or green led will light up to show if the wire is a power or ground wire. It cost about 45 dollars with tax.
Dave P
Old Jan 29, 2006 | 06:29 PM
Fordteamone's Avatar
Fordteamone
Dave Sounds like a good find. What is the part number? Thanks
Old Jan 29, 2006 | 07:03 PM
Chilako's Avatar
Chilako
one step up from that is the power probe. As well as being a test light that shows power or ground it has a built in ground lead and with the push of a button you can supply power or ground to a circuit. Comes with battery clamps and cigarette light plug. Great for wiring lights. Plus it is lit at the tip and has a 19' cable plus a 20' extension.
http://www.powerprobe.com/
Old Jan 29, 2006 | 08:26 PM
bosshoss's Avatar
bosshoss
I will get the number from the tool on monday. I love new toys.
Dave P
Old Jan 29, 2006 | 11:50 PM
Racerguy's Avatar
Racerguy
SnapOn makes the same sort of test light too.
Their part number is EECT301B and it sells for $76.50 according to www.snapon.com
Old Jan 30, 2006 | 07:16 PM
Panzerbrumbar's Avatar
Panzerbrumbar
I have some off brand led test light it is very nice and also has red and green leds. The only problem with them that I have ran into with it and maybe this is only 24 volt systmems that they are very senstive. The last time I had a problem with this was an ether start switch which ran through a sensor and the sensor let enough power through to light the led. A little frustrating when it should have worked so I found a old style bulb one that draws more amps. Then the light did not come on and had to replace the sensor. Just something to think about even though I grab my led test light first.
Old Jan 31, 2006 | 04:33 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I got the Mac LED test light 6 years ago for $35. It's got 2, red/green LED's in it, a pos and neg alligator clip, and does 6, 12 and 24 volt. It tells me if it's hooked up properly, if there's power or ground, etc.
Some guys call it a "logic probe".
Would have got the Snap On, but they didn't have it yet (back then).
