Front end trouble
Old Jan 28, 2006 | 09:53 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Front end trouble
My passenger side front tire is wearing on the outside only. The driver's side tire is fine. I never noticed it feathering, just slowly, actually not that slowly, wearing. The inside edge of the tire is OK, just the outside edge. The tread's actually gone already. I know I should have done something about it when I first suspected something was up in October. I'm thnking Ball joint, but just wanted to check with you guys before proceding.
Thanks
Old Jan 28, 2006 | 10:25 AM
BareBones's Avatar
BareBones
Any steering wobble or strange front-end noises? 4WD or 2?
Old Jan 28, 2006 | 11:02 AM
Munkey's Avatar
Munkey
Fullcrew7.3,
I'm suspecting your suspicious suspicions are correct!!
You might want to try and get the front end off the ground, stick a pipe, pole, crowbar etc under the front tire and lift it to see if there is any movement in the balljoint. Mine are sloppier than a sloppy joe!
If they are shot to heck, check out RacerGuy's thread on replacing the balljoints:
https://www.ford-trucks.com/forums/s...d.php?t=354091
Old Jan 29, 2006 | 08:43 AM
Fullcrew7.3
Sorry I forgot. 2wd. Why would it just be the one side? Just the one Ball-joint gone?
I noticed just a bit of noise/wobble when over 70. Not really noticeable before then.
Old Jan 29, 2006 | 08:47 AM
Fullcrew7.3
That link is for Super duty. How much different will it be for a '96?
Old Jan 29, 2006 | 10:10 AM
Beast12's Avatar
Beast12
Thread moved to 87-96 F-Series trucks forum.
-Matt
