elec prob
Old Jan 28, 2006 | 02:22 AM
jammex's Avatar
jammex
elec prob
Help would be appreciated in trouble shooting this problem.
We have a small RV with two battery setup. they have been draining for no explanable reason. had a new alternator installed and a new solenoid for the coach battery. now the coach battery is not receiving a charge. my guess is the new solenoid is not working correctly, How do you check a solenoid. It looks like a starter solenoid for a Chevy but is continuous duty, or is supposeds to be. your advice would be appreciated. thanks,
Old Jan 28, 2006 | 06:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 28, 2006 | 08:45 AM
subford's Avatar
subford
With the key in the "ON" position and engine running the two Batteries should have the same voltage when you check it with your meter.
Also the "PAR CHARGE SOL" should click when you turn the to the on position.
