I need to remove the top panel of the dash board my girlfriend dropped an earing down between the a pillar and the dash and I NEED to get it out
Any help is always appreciated
-steve
Just a thought, if you have a shop vac, try the small nozzle an see if it sucks it out. Just empty it out before trying, so you dont have to sort through all the dirt.
Driver's side or passenger? If pass, maybe you can get to it by removing the glove box. I'm not sure how to get that panel all the way off, but under the little (1 1/2" square or so) plastic caps on top, there are screws or bolts (I cant remember), remove those and the dash will loosen alittle. I did it on my truck to get the GPS antenna wire hidden. I also think if you pull the radio and front part of the dash around the guages, there's more screws there. It's pretty easy to remove that piece (and radio). Did you try pulling the door seal out to get a better look? Please post pic's of girlfriend.
