General Automotive Discussion
Auto Transmission question
Old Jan 27, 2006 | 08:48 PM
arin's Avatar
arin
I was wondering if there's really any difference between column mounted autos or the 'stick' type ones? I'd take a guess that maybe the stick-type ones are closer to the transmission/don't have to go through column, which maybe would be less parts to go wrong?
Old Jan 27, 2006 | 10:15 PM
okst1's Avatar
okst1
No, no real difference.
Old Jan 27, 2006 | 11:47 PM
JD717's Avatar
JD717
Far as I know, they both use the same parts, just one is closer to the tranny. no less to go wrong.
Old Jan 28, 2006 | 01:02 AM
pfogle's Avatar
pfogle
The only real difference is in the linkage. The floor mounted shifters use a cable instead of rods, so they are actually more prone to breaking because cables freeze up, where if you keep the linkages greased they'll last forever.
