swapping to power steering
Old Jan 27, 2006 | 07:43 PM
bikerwolfie's Avatar
bikerwolfie
been a long time since i posted anything, 69 f100 390, good truck good engine.
i have decided to change to power steering, got a good deal on a used pump and gearbox. anyway pump and gearbox is out of a 73 with automatic trans.
questions i have are
will the gearbox bolt up without any mods?
will the steering pump require a second pulley on the harmonic balancer?
will my steering column, 3 on the tree converted to the floor, work or do i need to get an automatic column?
if i need an automatic will one out of a 73 work?
as always thanks for your answers
Old Jan 27, 2006 | 08:17 PM
olbud's Avatar
olbud
your gear box will bolt up.you will need a double pulley for the crank and maybe for the water pump.you will have to use the power steering collum because the manual one is to long
