Help with MSD ignition/batteries
Looking into replacing my ignition stuff with MSD, just wondered if any one has any recomendations on them like which one to but or whatever. Also what all I'm going to have to replace.
im also wanting to replace the battery soon just wondered if anyone had any suggestions, ive been looking into Optima batteries but didnt know which one.
Thanks for any help
(i have a 1990 2.9L BII 4X4)
Thanks for any help
Recently installed an MSD 6A box on an 85 bII. Replaced the plugs with high performance bosch plugs, wires with 8mm fiber core (cannot use solid core with the 6A) and the coil with the MSD TFI coil. Very pleased with the results. Better idle, much stronger at lower rpm, better throttle response, smoother high end.
Couple of hopefully easy qtns:
whats the diff btwn a 6a and a 6al, or can i only use the 6a cuz the 6al is for v8?
i dont know a ton about cars but im trying to learn, so what all will i replace in the process of putting in a new ignition?
so get 6a ignition, MSD TFI coil, motorcraft plugs, and what wires b/c u both said two different kinds and i have no idea where thats at on their website. Any thing else im going to need?
Thanks for the help
Thanks for the help
