Sponsored by: Auxito
truck won't start
Old Jan 26, 2006 | 09:25 PM
Scotch24's Avatar
Scotch24
truck won't start
Hi every one
I have a 1997 Ford F-150 4x4 V8. I last drove it this past saturday and it was A ok. Now on sunday i hoped in and it wouldent start, it turns over but wont start. Its like its not getting enough juice or something ....any ideas ?
Any help would be great
Jason from Canada
Old Jan 26, 2006 | 09:30 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...88#post3272088 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 97-2003 F-150 forum.
See ya on the boards!
-Matt
Old Jan 26, 2006 | 10:56 PM
Grsyhands's Avatar
Grsyhands
Had this happen on a couple of vehicles but the one Ford I had an issue with was our SVT Rally Focus. Went in for breakfest before a stage, came out and no start. Turned out to be a fuel pump quit. Car had 5000 miles one it. Could be a place to start, check fuel pressure.
If you off road alot, you may want to check the roll over shut-off switch (can go by a number of names). They can trip with severe bumps etc. Usually located on the passenger-side, on the door side. Let me know if you need more detail and I'll look it up.
Old Jan 27, 2006 | 07:12 AM
projectSHO89's Avatar
projectSHO89
Air: Check by cracking the throttle. If it starts, your IAC is stuck closed.
Fuel: Check for adequate pressure (35-45 psi) at the rail. Can you hear the pump run for 1-2 seconds when the key is first turned to run? If not, check the inertia switch.
Spark: Check for spark.
One of the three is missing. Once you figure out which, the process of fixing it gets easier.
I could be as simple as frozen moisture in the fuel line in which case you may need to wait until spring.
Steve
