2000 Ranger No start
Are you saying the engine won't crank/turn over, or will it crank, but not fire/try to start????
If it'll crank, but not try to run, have you checked for fuel pressure & spark???? Have you checked in the under hood power distribution box, for blown fuses, bad diodes, or stuck relays & in the cab for a acting out fuel pump inertia switch????
If fuel & spark are ok, have you done a compression test, if so what were the numbers on each cylinder????
Have you scanned the computer for trouble codes, if so list all the codes you found.
