zf 5spOD info
The truck is rated 7500gvwr, 14000 gcwr, but won't be used quite that hard. Plan to use it for travel, aths events (www.aths.org), haul a camper, perhaps pull a travel trailer and occassionally some livestock.
Comments? Advice?
They have a built-in bellhousing, in both SBF and BBF formats. I believe the 400M has the same bellhousing pattern as the 460? If I'm correct, it's almost a bolt-in.
With a change in tranny mount, a hole in the floor, a home-made tranny hump, and the addition of a pedal/master cylinder assembly (which could be as simple as drilling 4 holes in the firewall), I think this would be a bolt-on.
My biggest remaining concern is reliability/longevity. The nv4500 is reputed to be better in that regard, though I've heard they have a nut which can come lose thereby leaving you with a handful of neutrals.
