Convert from Manual to Auto
Old Jan 26, 2006 | 02:16 PM
Garyinreno's Avatar
Garyinreno
How hard is it to convert from 5 speed to auto transmission if you have tranny and torque convertor. Can a normal home mech do it. And what else might i need. My truck is a 1991 ford ranger xlt super cab 4x4 with 5 speed..
Any help is wanted
Old Jan 26, 2006 | 02:56 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
If you're using an A4LD you will need to address the computer/wiring as this controlls the T/C. Then somewhere along the line there will be another wiring issue as with an auto you need to be stopped and in N or P to put it in 4L. Then there is the need for a tranny cooler, preferrably and ideally installed without a bunch of dangling rubber hoses leading to/from it. To address the shifter, finding an entire steering column woould probably be easiest; don't overlook adding the parts to the gauge cluster for the shift indicator. It can be done, it's just work with a handful of details to address is all.
Old Jan 26, 2006 | 03:09 PM
Garyinreno's Avatar
Garyinreno
Thanks it was just an option i have friend that works at a transmission sop and they have come across a new one stocked since 1991, i just liked the idea of having a newer tranny
