360 into a 428?
Old Aug 1, 2001 | 04:00 PM
jdbanks's Avatar
jdbanks
360 into a 428?
Ok, excuse my ignorance here. But I've read on here how you can turn a 390 into a 428 by boring it over and a new crank and all. And I've also read that a 360 and 390 are just alike except for the crank and rods. So What's to prevent turning a 360 into a 428 then? I've heard it can't be done but I am missing why it can't be done. Thanks for the time.
*jdbanks*
Old Aug 1, 2001 | 04:43 PM
luv70sfords's Avatar
luv70sfords
360 into a 428?
It can be done IF the block is of sufficient thickness to be bored to the proper bore. Is this 360 a 352 block, or is it the HD block with the reverse 105 on the front. If its the 352, Id just make a 410. If its the reverse 105, I see a 428 in your future.
Darrell Duggan
71 Stang "Cletus"
74 F-350 "Tweety"
71 Torino Conv. "Off-Limits"
Old Aug 1, 2001 | 05:00 PM
buzzard's Avatar
buzzard
360 into a 428?
Yeah, you've gotta be able to bore .080 over the standard 4.05" bore. Most of the time this cannot be done with a stock block. You'll have to have it sonic tested to see if your block is a candidate.
Old Aug 2, 2001 | 01:45 PM
karljay's Avatar
karljay
360 into a 428?
The difference is the rods for the 390 and 410/428 are different than the 360 rods. The crank for the 360/390/428 are all different.
The bore is really the big issue as it really requires sonic checking to see if it will handle 80 over. The crank for the 410/428 is not that hard to find for about $350 and the rods are pretty common.
Another option is to make a 40 or 60 over 410 using 428 crank flywheel and rods in a 360/390 block and then just bore to a safe clean point of about 40 or 60.
Pistons are another issue, you can flycut 390 pistons (L2291F) down to size as they have just over 1/2" of material at the top.
Old Aug 3, 2001 | 11:17 AM
ksd's Avatar
ksd
360 into a 428?
Even if you can't get .080 over for 428 cid, you can still usually go .060 over, which is good for 424 cid with a 410/428 crank. I doubt you'd miss those 4 inches. .040 over is roughly 420 cid.
ksd
69 F100 Explorer lwb 2wd FE 360 C6 3.25:1. WANTED: straight/clean styleside long box w/aux fuel tank for 67-69 F series.
Old Aug 3, 2001 | 11:36 AM
6t6merc's Avatar
6t6merc
360 into a 428?
