more pulling power
Old Jan 26, 2006 | 09:18 AM
paulwillett8's Avatar
paulwillett8
more pulling power
My brother has a 1991 f250 with a 300 six and 354 rear end. He has 235 tires on the truck and it is speced with 215. Will he get more pulling pulling power if he went back to the 215s? Or should he install a 410 rear end. Another option he has is swaping his six for a 302V8. Any help would be appretiated.
Old Jan 26, 2006 | 10:15 AM
Galizien's Avatar
Galizien
410 gears are worse for pulling I think. I would think he should go with 2xx gears. And if all he needs is pulling power, the 4.9 would be better than the 5.0.
That truck with 2xx gears would pull a house off its foundation.
Old Jan 26, 2006 | 10:19 AM
s8whiskey's Avatar
s8whiskey
haha get some good ol 288 gears. Those are whats in the old school Mac trucks that did the ice haul up north made sure they could pull anything out and its like a governor for speed I was told.
Old Jan 26, 2006 | 10:26 AM
Galizien's Avatar
Galizien
lol I knew this one guy who had a 64 chevy 3/4 ton, it had 273 gears in it I think, first gear was basically 0-4mph and that was full RPM on the 350 that was in that truck. I think he used to start off in 3rd from a stoplight. In 3rd gear, he could let out the clutch with zero gas and the idle power of the truck would keep it from stalling.
I think it was 273 gear in the rear and the tranny had a granny gear in it or something. It was basically useless unless you were doing nothing but hauling.
Old Jan 26, 2006 | 11:37 AM
Kemicalburns's Avatar
Kemicalburns
you guys are all smoken crack hehe.
the 4.10's will alow him to tow alot better for sure especially with that motor. the 302 is a crap motor in a truck used for towing. a 302 is a hi rpm motor and really doesnt produce that much torque. if he wants to swap to a v8 he should do a 5.8 swap. its the same amount of work as a 302 swap , he can use the same tranny thats already in there.
the higher the gear ratio the better pulling you will have. the lower the gear ratio number the more power loss it will feel like.
Old Jan 26, 2006 | 11:38 AM
andym's Avatar
andym
You guys all have your gear ratios backwards. Edit - except for Kem. Beat me to it.
Numerically higher = better pulling, worse gas mileage
Numerically lower = worse pulling, better mileage.
Paul, as for the tires, 215 and 235 refer only to the width. I doubt that an F-250 called for 215 wide tires from the factory. Going to a smaller diameter tire will help with power, but I'd go with a gear ratio change. A 300 needs 4.10 gears to pull really well in that heavy truck.
Swapping to a 302 would be a big mistake. We've had this debate recently, and I don't want to rehash it, but most people (myself included) are of the opinion that the 300 will outpull the 302 any day of the week.
If you really want to make the swap worthwhile, get a 460.
Old Jan 26, 2006 | 01:31 PM
Galizien's Avatar
Galizien
NVM you are right, I did have it backwards
Old Jan 26, 2006 | 02:23 PM
s8whiskey's Avatar
s8whiskey
Hmmm Im most def going to take your knoweldge just why did the older trucks use the lower gears?
Old Jan 26, 2006 | 02:54 PM
Kemicalburns
it depended on tranny type for instance. how the truck was ordered. etc...
most 2wds will have like a 2.** or 3.08 for instance especially if its a halfton.
3/4 - 1tons mostly came with a 4.10 both 2wd or 4wd models due to weight of vehicle and expected uses.
Old Jan 26, 2006 | 03:12 PM
handyman43358's Avatar
handyman43358
Thats the funniest thing I've heard today! Thank God you stopped the madness before I did! I wouldn't have been so nice about it lol.
Old Jan 26, 2006 | 03:39 PM
turbocoupe5.0's Avatar
turbocoupe5.0
The tire width does have an effect on tire diameter on tires using the metric designations.
For example: 235/85R16
235 = tire section width (not actual tread width) in millimeters
85 = the aspect ratio in % (the height of the side wall is 85% of the section width
R (I believe the R means radial but I'm not sure)
16 = rim diameter in inches
So the diameter of this tire would be (235mm X 0.85 X 2) + 16in = 31.7in
Note: To convert millimeters to inches, divide the millimeters by 25.4
235mm / 25.4 = 9.25in
If you increase the section width without changing the aspect ratio, the tire diameter will be larger. To keep the same diameter with a wider tire, you must decrease the aspect ratio.
None of this applies to the older tire sizing convention, for example, I run 33 X 12.5 X 16.5 tires on my truck. They are 33in in diameter, 12.5in section width (not tread width) and fit a 16.5in diameter rim.
Tread width is independent of section width. See the tire manufacturer's spec for this and rim width recommendations. My 33 X 12.5 x 16.5 BFG AT's have a tread width of 10in.
Old Jan 26, 2006 | 03:40 PM
turbocoupe5.0
Oh yeah, a larger diameter tire will act like a numerically lower gear like a 2.XX. A smaller diameter tire will act like a numerically higher gear like a 4.XX.
Old Jan 26, 2006 | 03:58 PM
whiteyfordzx5's Avatar
whiteyfordzx5
ford didn't make a 3.73 back then did they? to me, that would seem a good compromise. 4.10s will help you pull no problem, but your mileage will be in the toilet when you're unhooked!
Mike
Old Jan 26, 2006 | 05:04 PM
handyman43358
Very well put Turbocoupe. I myself learned quite a bit from your post and I thank you for that. I never 100% fully understood how those numbers worked. The only question I have is what is the difference between tread width and tire section width? Reason I ask is because my ranger calls for 215/75R-14's, but right now I'm running 205/75R-14's Let me try the math...
(205 x .75 x 2) + 14 = 321.5mm. Divide 321.5 by 25.4 to convert that to inches right? That gives me 12.65 inches.
Now I'm confused. Either I had a brainfart... or I still dont get it! lol
Old Jan 26, 2006 | 05:13 PM
whiteyfordzx5
you converted your number too early.
it's ((205*.75*2)/25.4)+14 = 26.106
here's a nice tire size calculator for ya:
http://www.1010tires.com/TireSizeCalculator.asp
Mike
