1978 - 1996 Big Bronco
86 ford bronco centurion
Old Jan 26, 2006 | 08:03 AM
jorock's Avatar
jorock
Hi all, I think this is the first time i have posted but I have looked througt the forums for some time and have come across some great info. O.K. heres the queston. My cousion has an 86 ford bronco centurion 2wd on a f350 chassi and it has a 460 in it now. He wants to upgrade to a efi 460 that he already has. I know he would have to add a electric fuel pump but other problems would he have. Thanks in advance.
Old Jan 26, 2006 | 11:49 AM
Kemicalburns's Avatar
Kemicalburns
he would need the entire wiring harness then locate a computer that had a 460/c6 combo. otherwise it should all work out. try searching on the web as well
Old Jan 26, 2006 | 04:17 PM
jorock's Avatar
jorock
he has the computer and engine wiring and the trans already but I think is an e40d
Old Jan 27, 2006 | 08:41 AM
Kemicalburns
if he has everything then that tranny will work out. but he will need a different rear axle with a vss in it. thats how those trannys work properly. a sterling 10.25 would be perfect. otherwise he may have to stick with a c6.
