Question for Autoenginuity users
Old Jan 25, 2006 | 10:05 PM
schmity's Avatar
schmity
Just bought Autoenginuity for my palm pilot with the enhanced ford version. Have a few questions.
The KOEO test returned the following DTC: P0605 Internal Control Module Read Only Memory (ROM) error.
Also, some of the sensors are static and are either stuck on zero or stuck on their maximum limit. I'm sure there are more, but here is a quick list of the ones I have looked at.
Barometric Pressure - Hz
Barometric Pressure - PSI
Barometric Pressure - Volts
Barometric Pressure Input
Calculated Engine Load
Desired Engine RPM
Intake Air Temerature (2nd on list)
Intake Air Temperature Input
Intake Air Temperature Status
Manifold Air Pressure (Hz)
Old Jan 26, 2006 | 12:32 AM
jtharvey's Avatar
jtharvey
You might check with users PinkGear or PSNut. I think both of them have the software.
Old Jan 26, 2006 | 06:45 AM
ntan's Avatar
ntan
Hey Schmity, your scanner is reading your HP chip or tuner program. You have to reset your computer to factory settings or remove your chip in order to get the right readings. This code will show up with the modification.
Old Jan 26, 2006 | 11:30 AM
schmity's Avatar
schmity
Switched the chip back to the stock setting and got rid of the P0605 Code. However some of the sensors still don't seem to be working right. Has anyone checked these sensors on their truck. It's funny, for example, how the "Barometric Pressure" seems to be correct, but "Barometric Pressure - Hz" constantly reads the maximum limit of 172 Hz and "Barometric Pressure - PSI" constantly reads 0 psi. There is a similar situation for the ECT, MAP, and IAT. Also the calculated engine constantly reads 0%.
I called Autoenginuity and they said to doublecheck on another truck, but the only other truck I have is a 95 model, and it doesn't show anything. Thought I might could double check with someone on this site instead.
