Silly Question??????
Old Jan 25, 2006 | 05:36 PM
jb's94f-250's Avatar
jb's94f-250
ok i just put my 94 f250 in the shop to get the tranny rebuilt ...question is would my tire size have anything to cause the tranny to fail on me? trans is a e4od..tires are 33..12.50..16.5? seems this is the second time to have rebuilt.
thanxs for any help for this trouble some matter
Old Jan 25, 2006 | 07:17 PM
vman's Avatar
vman
Kinda hard to say.Were any upgrades done to the trans?Did you reset the psom when you went to bigger tires?I put bigger tires on mine and the trans.labored and lugged instead of shifting when it should have.
Old Jan 25, 2006 | 08:38 PM
torquemeister's Avatar
torquemeister
If the computer was never 'told' what size tires were put on it, it's going to do all of its calculations assuming it has the same size tires it came with originally. Since your new tires are larger than stock, it will be slightly off as far as your MPH, odometer, and your shift points. You can get the exact difference on this page:
http://www.csgnetwork.com/lttrucktireinfocalc.html
Your new tires mean you're actually going a little bit faster than your speedo says, and slightly fewer miles than your odometer indicates. Also your tranny will be shifting at the wrong times. If it was a manual tranny, it wouldn't matter at all.
-Chris
Old Jan 26, 2006 | 11:26 PM
smecomark1's Avatar
smecomark1
33..12.50..16.5, that tire size is only wider than stock, it is the same diameter (or very close) to the stock tire.
My 88 F250 stock tire per door sticker is LT255/85R16 which is a 33-1/2" tire,
Its not likely the tires causing the Tranny problems.
You should have posted the problems you were having, could have been something easier than you thought, modulator, torque converter, band adjustment?? A tranny shop will fix it but they will probably not show you the bad parts or offer an explanation as to why it failed, you really need to know that above all.
Old Jan 27, 2006 | 12:50 PM
preppypyro's Avatar
preppypyro
Most of the time, tires wont harm anything, except if you have different sizes of tires on each axle sorta deal. The tranny might labour a little bit more at the shift points, but I dont think it would be enough to harm it much!
