Sponsored by: Auxito
Won't Start
Old Jan 25, 2006 | 09:11 AM
mrtrick101's Avatar
mrtrick101
Question Won't Start
Hello,
I have a 2000 Ford F150, 5.4! Replaced valve cover on passanger side due to bad oil leak. Now the truck won't start! It turns over fine, but nothing else! Any ideas on where I should start looking for the problem?
mrtrick
Old Jan 25, 2006 | 10:24 AM
BillyBob69's Avatar
BillyBob69
Fuel rail? Getting fuel to it?
Old Jan 25, 2006 | 10:50 AM
mrtrick101's Avatar
mrtrick101
Yes, getting fuel to rails!
Old Jan 26, 2006 | 12:19 AM
Racerguy's Avatar
Racerguy
Did you get it figured out yet?
Is the wire to the crankshaft position sensor plugged in?
Old Jan 26, 2006 | 07:46 AM
mrtrick101's Avatar
mrtrick101
I have not solved the problem yet! If that is the sencor at the front of the head next to the valve cover, yes, it is connected.
Old Jan 26, 2006 | 01:06 PM
mrtrick101's Avatar
mrtrick101
New set of problems!
Okay, here is my problem. Short in wiring to crankshaft sensor, COP bad, and coolant in #6 cylinder! How can I remove the coolant without tearing down the engine? Is it possible?
Canty
Old Jan 26, 2006 | 05:04 PM
mnl119's Avatar
mnl119
You shouldbe able to pull the plug from cylinder #6, turn the car over afew times, and that should clear the coolant. This of course won't solve the problem of how the coolant got in there in the first place.
Old Jan 27, 2006 | 07:25 AM
BillyBob69's Avatar
BillyBob69
Coolant in the cylinder...if I am not mistaken, is a head gasket problem.
Old Jan 27, 2006 | 07:55 AM
projectSHO89's Avatar
projectSHO89
Depends if the coolant was inside the cylinder or if it was just in the plugwell.
If the plugwell, an external leak.
If inside the actual cylinder, well......
Steve
