Auto Vs. Manual
Old Jan 25, 2006 | 06:33 AM
BLKFE's Avatar
BLKFE
Auto Vs. Manual
OK, So now that I know it can be done, the question is should it be done.
The Truck is a 1995 F-350 460EFI crewcab dually with 96,000 miles. Currently has a E4OD which seems to be getting weak. Will a 5 speed out
of a 1992 F-350 460EFI be a good swap. I pull a 35 foot 5th wheel. This
Truck and camper combo weighs in at 19,000 empty. (no kids,dogs,cats, H2O, food, ect. Would the manual 5 speed handle it in OD ? Would it handle it at all? Would it be more reliable than the auto? (run cooler ect.)
Thanks for all your input!
Old Jan 25, 2006 | 11:35 AM
andym's Avatar
andym
I don't know why you started a new thread...
It's basically personal preference. If you don't mind shifting, go for it. You never have to worry about overheating a manual tranny, and they are much more reliable.
Old Jan 25, 2006 | 12:27 PM
frederic's Avatar
frederic
The ZF 5-sp will handle it just fine. The question I was ask myself is do I have the experience towing a heavy load (like yours) with a manual transmission?
If not, you're going to be replacing clutches until you gain that experience. The clutch (when new) is a little forgiving of mistakes in an unloaded truck, but with 19K attached... it's not.
Personally, I prefer a manual. I like the low maintanence, the slightly better mileage, and having more control over what gear I'm in.
Old Jan 25, 2006 | 02:25 PM
BLKFE's Avatar
BLKFE
Thanks
Thanks for the info.
Sorry about the new thread. I still learning.
Brad
Old Jan 25, 2006 | 09:16 PM
gpfarrell's Avatar
gpfarrell
Brad
Me too. That's why I was glad to read your new thread.
Btw, I like my 5-speed... flew 1400 miles to get it and drive it home... but I think the point above about driving a stick being a bit different with 19,000 pounds attached is a good one.
'Course, most everything about driving is a bit different with 19,000 pounds attached!
Old Jan 26, 2006 | 06:56 AM
BLKFE's Avatar
BLKFE
3208 Cat in 83 ford
Cool,
About 15 yeard ago I helped my Father put a 3208 v-8 Cat in his 83 supercab. We also installed an overdrive. I think he called it a brownie.
Anyway, he alway told me it was for running empty and not to use it towing.
I guess thats why I asked about the OD in the 5 speed.
Driving that truck was an EXPERENCE!!
Brad
Old Jan 26, 2006 | 07:09 AM
frederic's Avatar
frederic
Well, if you guys swapped the cat in with a standard pickup transmission, that's why.
had you guys swapped in a clar 7sp or something equally strong, you could have not worried about the tranny breaking.
For a short while, I was seriously considering building the 500cid stroker I'm working on out of a F500 429 block... which has the generic round bolt pattern, thus giving me access to "big truck" transmissions as well. Then I realized, driving a 7, 9, 15 speed unloaded was a pita
