My C6 has developed a wierd little chirp when I drop into reverse first thing in the morning. Only when the engine is on fast idle (1,000rpm). Otherwise it's fine. Anyone experience this before? Seems like everytime I get caught up something else needs attention!
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
It could be your driveshaft... there is some slop between the tranny and rearend so when you switch from forward to reverse the shaft jerks... check your u-joints and make sure they are greased and tight...
