Sponsored by: Kumho
u-joints?
Old Jan 24, 2006 | 09:23 PM
bigjace8's Avatar
bigjace8
u-joints?
i know this is fte but i have a pre-ford mazda question. i have a 91 maz b2600i that has been lowered 3 inches in front via torsion bars and 3 inches in rear via steel lowering blocks. its been like this for 4 years now. i recently changed the tranny filter and gasket (my 1st time ever) well now the truck gets a nasty vibration every once in a while. very violent shakes everything to hell. seems like a driveline vibe. any ideas? the u-joints have never been changed and i know the tranny mount is shot to. i will prolly change the u-joints and mount neways. but i still wonder if that will cure it
Old Jan 25, 2006 | 04:20 PM
SRD4X4's Avatar
SRD4X4
Changing the fluid should have had no affect,but anythings possible.Wheres the vibration? (seat,steering wheel) When does it happen?(high/low speed,accelerating,etc.).Tranny mount will do do it for sure.
Old Jan 25, 2006 | 11:47 PM
bigjace8's Avatar
bigjace8
the vibe runs through the whole truck and shakes EVERYTHING bad. only happens once in a while around 20-30 mph accelerating. thanx
Old Jan 25, 2006 | 11:54 PM
someday's Avatar
someday
sounds like the torque converter is shuttering...did u use the correct tranny fluid?...when it shutters does it go away after taking your foot off the accelerator and reapplying it?
Old Jan 26, 2006 | 11:53 PM
bigjace8's Avatar
bigjace8
it does go away after doing exactly that. i needed i think it was dexron 2 and i used a (universal type) the label said it will work for my application. im not positive it was dexron 2 but i do know i had a hell of a time finding something even close.
