OBD2 port went bad
Old Jan 24, 2006 | 07:59 PM
redneck8's Avatar
redneck8
OBD2 port went bad
I have a 97 stroker and a superchips programmer and I am at my high perf setting on the tuner, but it recommends not to tow with this setting so I went to change it to tow-perf and I plugged it in and nothing happened. I plugged it into my buddys truck and it lit right up, my question is can I swap ports with a 96 powerstroke or do i have to get this from the dealer. My port has a pin that is gone. Thanks
Old Jan 24, 2006 | 09:16 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Make sure you don't have any blown fuses, as there is something else that is also powered through that ports fuse. Cigar lighter maybe...can't remember.
Old Jan 24, 2006 | 09:54 PM
redneck8's Avatar
redneck8
thanks cookie, i will check that out and make sure it is not it.
Old Jan 25, 2006 | 08:01 PM
redneck8's Avatar
redneck8
checked it all out today and sure enough I throw my change in the ashtray and a penny got into the lighter outlet and blew the fuse, replaced the fuse and i was good to go. Thanks for your help.
Old Jan 25, 2006 | 08:08 PM
cookie88's Avatar
cookie88
FTE Emeritus
No problem. Glad it was an easy fix.
