Rust on Drip Rail
Old Jan 24, 2006 | 07:30 PM
bandit990's Avatar
bandit990
Rust on Drip Rail
I recently purchased a 1990 f150 4x4 regular cab. There is major rust on the drip rails over the doors on both sides and its begining to work its way onto the roof of the cab. the roof doesnt have too much yet but the rails are what is concerning me. Is it possible to remove the rails and if not what should i do?
Old Jan 24, 2006 | 07:51 PM
Ford150/428/dud's Avatar
Ford150/428/dud
Blast off the rust in the seam prime it and put a water proof sealer in seam and paint it. also you may want to take the head liner out and see if the rust has traveled into the inside of the cab.
Old Jan 24, 2006 | 09:14 PM
bandit990's Avatar
bandit990
is there something i can use to fill to gaps?
Old Jan 24, 2006 | 09:24 PM
mat-helm's Avatar
mat-helm
Fiberglass, or you could shave (cut) the drip rails off. But that may be a little more involved than you're ready for. If you can't find a hand heild sand blaster, you could use a wire brush, or better yet, a wire wheel brush you could use with a drill. Then pick up a can of bondo hair ( fiberglass paste ) and a pack of spreaders at Advance. Slop it in where you need it, sand, prime and paint.
Old Jan 24, 2006 | 11:09 PM
bandit990's Avatar
bandit990
i have a dremmel so il prob figure out a way to use that, the fiberglass sounds like a good idea. I think i will just taper the rail so its about half as long.
thank you guys for the quick replies
