fusable link/alt Question
Old Jan 24, 2006 | 06:14 PM
gearheadz80's Avatar
gearheadz80
I'v got a '00 E-450 and on my way to work this morning the van completely shut off. No power anywhere. Found the fusable link to the starter relay was burnt. Replaced the link and was hooking the wires back up and burned that one up also. Could maybe the altanator regulator be bad and giving it more voltage and burning up the links?. This all happens as soon as I hook up the battery and it throws sparks. The key is also off position. The alt is 2 weeks old and also new batteries. Any suggestion would help. Should I have alt tested? or could the be anything else to look for? Thanks for any help <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Jan 24, 2006 | 07:03 PM
aurgathor's Avatar
aurgathor
Most likely a major short somewhere after the starter relay.
Old Jan 24, 2006 | 09:02 PM
gearheadz80
Do you mean from the relay to the starter? or the relay? A frayed wire?
Old Jan 25, 2006 | 01:24 AM
aurgathor's Avatar
aurgathor
A blind guess would be a voltage regulator, but could several other things, including alternator that are before the wiring and circuits protected by fuses.
Old Jan 25, 2006 | 06:30 AM
Franklin2's Avatar
Franklin2
The problem can be from the starter relay to the alternator, or the main wire from the starter relay to the fuse box. The starter will have nothing to do with this problem.
Old Jan 25, 2006 | 01:47 PM
gearheadz80
Fixed--------The alt had a short in it, replaced it under warrenty. Thanks for the help
