2006 Duramax 4wd vs. my F150?
#33
#34
I think that was possibly the worst move they had made engine wise since the late '70's 350 gas/diesel convert. CAT would have possibly given them a contender with the PSD. Ford had a betetr truck...but like with the Cummins, people would see CAT, and be all over it. They couldn't do it due to weight...and GM wasn't prepared to go solid axle. It's a shame, they could have introduced CAT into the light truck market.
#35
no i don't think CAT did their homework. because if they did, weight would not have been an issue. the duramax is making awesome hp, that only the dodge boys can top regularly. there are on a couple PSDs that can even touch the other 2's numbers. the CAT would have been a great marketing name, but from what i have heard, it is a lot of hype for nothing. Izuzu is probably more world know, more so than CAT.
By the way, how could the duramax be the worst?. The worst would have been staying with the 6.5 that wouldn't move. The duramax has moved market share up a lot not just a little.
I don't know how you can slam GM with it's worst engine move, after what the 6.0 cost ford.
THAT WAS THE WORST ENGINE MOVE NEXT TO THE 350 DIESEL OF GM.
#36
Originally Posted by tmyers
I would tend to agree Nick as far as the Dmax dynoed at 270 unless it is a 4X2 model and a manual. There is no way you are going to get only a 10% drive train loss if you have a tranfer case and a auto. More like 20-25%.
My auto is the most efficient stock auto I have ever seen. My Vette is stock and has been on the dyno, 337/341. The manuals run about 20 more in both. That is rated 400/400 at the flywheel.
And you right it is the 4x4 that is getting these guys launched and that is the reason they are getting into the 12's. There is no way they could ever launch with a stock suspension setup with just the rear wheels with the amount of torque those engines put out.
#37
#38
so, all you guys touting the new cummins as being the shizzle....
what are they runniing?
i drove an 05 here at work, had a bully dog something or other on max.....underhood box, not a programmer... lets just say i was less than impressed.
my 6 with just an scmt, and no muffler would kill it.... not to mention, i run 35's, and stock 3.73 gears.
granted, i have seen some dyno numbers, but yet to see a video, or come across one on the road that can keep up....im sure they exist, but where are these bad *** trucks?
and as to launching in 4wd..... i would NOT advise doing that in a chebby!!!!!!!!!!
if ya do, you are an idiot. no doubt about it.
the front axles on those pigs are seriously undersized.......as is the carrier and ring gear for that matter....
#39
#40
#41
every cat i have been around has been a 3208, and i was far less then impressed with the engine.
so if they, CAT, offered the smallest diesel available, then why the heck did it have to weigh 3 ton. personally the duramax is too heavy now. you drive offroad in 4x4 territory, you might or might not get stuck with the diesel, but if your gas conterpart gets stuck, the diesel prolly won't pull out the gas, because the diesel will sink. the gasser on the other hand can't pull out the weight of the diesel. 2 gassers can go offroad, and if the other person gets stuck, atleast they can pull each other out. i don't want SFA. you guys can have it. let alone a heavy brick for a diesel.
guys this is still a truck. not a semi.
SO IF that is the reason, i can see why gm turned down CAT. they didn't design a motor that would fit with what they had.
BTW you can race in 4x4 and even boost launch in 4x4 stock, but if you are limping the allison, then odds are your tierod ends will break the allisons and the tie rod ends go at about the same hp levels. the rest of the 4x4 system will take the power fine stock.
THE FRONT AXILS ARE PERFECT unless you are running 39 inch tires and going to the truck pulls with a lift and the torsion bars cranked all the way up.
BTW this was a ford guy that said that on the DP. he said they chevy front end was weak. we never laughed so hard.
39 inch tires, a 6 inch lift, and God knows how many RWHP, and he blaimed the front end of the chevy for breaking, oh and he still had the stock tierod ends. that is prolly the only reason the axil broke to begin with.
Only thing CAT has is a name.
BTW there is a 7.8 liter inline 6 dmax.
when cat is put up against other engines in the same sevice life interval, it doesn't make since to own a CAT because they cost more to begin with, and you aren't guarateed any longer service life. the only thing you are guaranteed is that when it comes time to rebuild that diesel, it will cost you an arm and a leg.
my .02 is you are paying a lot for the name. it is stupid in my opinion.
#42
i don't want SFA.
#43
#44
In my opinion you are stupid.
#45
Originally Posted by NickFordMan
Proof? This doesn't make any sense, since the Duramax is just a name that GM put over an Izuzu designed and built engine. There is no 7.8L inline Dura.
Its available in anything from the C6500 up.
http://www.chevrolet.com/mediumduty/kodiak/c6500/
