Ignition Problem
Old Jan 24, 2006 | 03:11 PM
OLDTRUCKMAN's Avatar
OLDTRUCKMAN
Ignition Problem
Ok I Guess I Am Right Room Now. I Had A Question About A Push Button Switch And How To Take It Out To Use Key Switch. I Am New And Was Told To Come Here. Any Help? Thanks Guys
Old Jan 24, 2006 | 03:20 PM
Mil1ion's Avatar
Mil1ion
Button back to switch !
This is the only thing you need to know ?
A I assume the ignition switch has gone bad.
This can be replaced with little trouble.
Questions about the truck
Q: What year is it ?
Q: Auto trans or manual ?
Q: Is there a FORD starter solenoid on the truck ?
Q: Does it have all the Ford ignition equipment as opposed to after market ignition parts? (DurasparkII)
Old Jan 24, 2006 | 03:34 PM
OLDTRUCKMAN
Ignition
New Key Switch, New Key Cylinder, New Ignition Module, New Solenoid. Funny Thing, The Truck Will Start In Any Gear. I Bought The Truck From My Neighbor. I Am The 3rd Owner. It Has 114,000 Miles, Auto Transmission, 351 M. The Last Owner Installed A Push Button Switch To Start It.
Old Jan 24, 2006 | 03:35 PM
OLDTRUCKMAN
79, I Am Sorry
Old Jan 24, 2006 | 05:14 PM
Mil1ion's Avatar
Mil1ion
Okay,I checked your profile to find out you are talking about a 78.
There should be a NSS on the side of the transmission with some wires running up to the center if the firewall with a grey or brown connector.
It looks like this
https://www.ford-trucks.com/user_gal...100323&width=0
Let me know of it is there
Old Jan 25, 2006 | 09:49 AM
OLDTRUCKMAN
i will look tonight when i get off work. thanks for the help. how do i know if this is the problem? is there a way to check it? also how do i rpleace it, alot of hard work or is it easy.
thanks, mike
Old Jan 25, 2006 | 10:51 AM
Mil1ion's Avatar
Mil1ion
Someone might have looped the circuit.
Let's determine what you have or don't have first
Old Jan 25, 2006 | 11:12 AM
OLDTRUCKMAN
thanks, i will check it
