rusty leaf spring hangers
Old Jan 24, 2006 | 11:40 AM
steeldust's Avatar
steeldust
hi there. i discovered that my rear leaf spring hangers are pretty rustyand need to be fixed/replaced. does anyone make these? i searched the junkyards to no avail already. i wonder if its possible to fix these while still on the truck? any ideas on this? thanx very much
Old Jan 24, 2006 | 11:46 AM
steeldust's Avatar
steeldust
sorry. i forgot to put model- 78 f-250 4x4
Old Jan 24, 2006 | 11:52 AM
1975Ford's Avatar
1975Ford
National parts depot (npdlink.com), look in suspension portion and the parts name is a shackle (part number F-5776-8). Have the vin number with you when ordering your part
Old Jan 24, 2006 | 01:15 PM
steeldust's Avatar
steeldust
hi 75ford. thanx alot for the link. the part im searching for is the part that the shackle attaches too. the part that attaches right to the frame. i couldnt see anything for my yr in that catalog though. thanx alot
Old Jan 24, 2006 | 02:12 PM
1975Ford's Avatar
1975Ford
Might want to try a junk yard.
Old Jan 24, 2006 | 02:16 PM
amish77's Avatar
amish77
he already tried a junkyard.
They aren't that complex, if you can find a metal shop they should be able to make you some, so long as you bring the old ones in. You could also make some yourself if you have the tools.
Check out Jeff's bronco graveyard and LMC trucks for more vendors.
Old Jan 24, 2006 | 02:19 PM
steeldust's Avatar
steeldust
hi. thanx for reply. i found them at Lmc trucks.cool!
