Spedo cable kaput !!!
Old Jan 24, 2006 | 11:22 AM
guitar_199's Avatar
guitar_199
How hard is it to replace the spedo cable in a 1987 F150, 4 speed?
Do you normally replace the outer housing or just the inner core?
Old Jan 24, 2006 | 01:25 PM
Lazy K's Avatar
Lazy K
If you can pull the broken bits out and the outer cable is not kinked or damaged then just replace the inner core. Disconnect it at the instrument cluster end and pull the inner. You may have to do the same at the trans. to get the broken bit out. Lube the inner to within about 6ins. of the speedo and feed in.
