Sponsored by: Real Truck
switched hot line
Old Jan 24, 2006 | 02:50 AM
TDELONG83's Avatar
TDELONG83
switched hot line
where would be a good place to tie into a hot power line that is switched by the key ?
Old Jan 24, 2006 | 10:30 AM
CmprSpecial's Avatar
CmprSpecial
It differs slightly by year, but check this thread where I posted the answer for a 2003 https://www.ford-trucks.com/forums/s...d.php?t=453416. You have an '04 according to your profile, it's in roughly the same place. The link I gave will lead you to other years, you can research there. Look for the "PTO Wiring"
Old Jan 24, 2006 | 01:13 PM
TDELONG83's Avatar
TDELONG83
Thanks for the answer, but i could not get that link to work should i be looking for a pair of empty wires or will i have to splice into a harness.
Old Jan 24, 2006 | 01:18 PM
CmprSpecial
For some silly reason this site adds "http://" to the front of the link. Since my link already included it, the link failed. Try this one http://www.fleet.ford.com/truckbbas/...bb_pdf/187.pdf it's for the 2004..
There is a bundle of wires labeled "customer access circuits" or something like that just behind the radio. You don't have to pull the radio, just look under the dash behind it. There is a white wire with a light blue trace. That wire is switched hot when ignition is in run. I used it to power a relay that then powered my switch box for all my lights.
I also used the pass through wires so I didn't have to add extra holes in the firewall... Heck, they are there, why not?
Old Jan 24, 2006 | 07:30 PM
TDELONG83's Avatar
TDELONG83
Thanks very much that link worked and will be very heplful..thanks again
