New Gauge face finally installed!
Old Jan 23, 2006 | 08:37 PM
cangim's Avatar
cangim
Here are a couple of pics of the gauge face I installed, matches the phantom gauges pretty good. Night pictures are blurry, but will have to do until I get some better ones taken.
[https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=103490&.jpg
https://www.ford-trucks.com/user_gal...id=103491&.jpg
https://www.ford-trucks.com/user_gal...id=103492&.jpg
Old Jan 23, 2006 | 09:07 PM
CAT_man_963's Avatar
CAT_man_963
Shoot that's darn nice!! How hard was it to actually put on?? I'd love to do one, but I've heard they are a real pain in the 'yaknow' to put on.
Old Jan 23, 2006 | 09:11 PM
jtharvey's Avatar
jtharvey
Great new look!! I like the way it matches your A-pillar guages.
Old Jan 24, 2006 | 03:10 AM
cangim's Avatar
cangim
Thanks, actual install was pretty quick, maybe an hour taking my time not to break anything due to the plastic being cold. Doing it again, I wouldn't put the needles back on until you turn the key back on, had to do it twice. First turn key on, mark locations of needles. Remove radio, two screws above radio that need to come out. Remove dash bezel, remove four screws for the cluster. disconnect three plugs in back as well as three is a little adjustment screw for the drive selector (autos only) under the column, just disconnect cable and unthread out all the way. Remove cluster, I took it inside and sat it above a vent to heat up. The clear section comes off with four snap tabs. Remove needles, peel off old face, stick on new, then part I ended up doing after assembling it once, take it out plug all together for the cluster, turn key on, then set the needles. That way you don't have to do it twice. This was the only one that I found red, most had flames, which I didn't want and one had blue, which I thought of, but wanted red.
Old Jan 24, 2006 | 11:16 AM
1BIGTOY's Avatar
1BIGTOY
Where can I get one of these gauge faces?
Old Jan 25, 2006 | 12:37 AM
cangim's Avatar
cangim
My particular face was made by APC (american products company).
http://www.performancestyleattitude.com/home.htm
Also, one of our sponsors carries gauge faces as well
http://www.stylinconcepts.com/part_f...categoryID/357
I found mine on ebay, there are many different styles available, I wanted plain red.
Old Jan 25, 2006 | 06:27 AM
cangim's Avatar
cangim
Okay, so I updated my gallery with some better pics so the top links will no longer work. They are in the Gauges and Lighting album
