4X4
Old Aug 14, 2001 | 11:35 AM
AaronW's Avatar
AaronW
4X4
I found a cheap 77 4X4, 351M 4SPD. He says the frame and underside is in good shape, is there anything else to look for on a 4X4 that would be in bad shape?
THanks
Aaron
Old Aug 14, 2001 | 06:15 PM
1ole4d's Avatar
1ole4d
4X4
You might want to check the transfer case out. Put it in 4wd and test it out. Check all the usual stuff. Brakes, body cond., lights. Better check your window and door seals too. Try the heat and a/c to make sure they work also. Check for any major leaks around the tranny, transfer case and front and rear diff's. If everything seems solid or ok. I'd go for it.
Robert
1978 F-150 4x4 Stepside 351M
Please don't pull out in front of me! The last thing I want to do is play identify the pieces with you or your car.
Old Aug 14, 2001 | 07:08 PM
frenchie's Avatar
frenchie
4X4
Zookie400
Connecticut Chapter
32
Oct 12, 2010 02:01 PM
dyhrdford
Aug 7, 2007 06:41 PM
engineguy33
Nov 24, 2006 09:55 AM
77hiboyboy
Offroad & 4x4
Jan 21, 2004 03:03 AM
AaronW
Oct 1, 2001 05:57 AM
