right front shake
Old Jan 23, 2006 | 03:04 PM
biggman70f100's Avatar
biggman70f100
Question right front shake
I recently bought a 70 model f100 and just getting around to fixing all the bugs. One problem is the right front shakes real bad and gets worse the faster you go and the wheel actually hops. The radius arm bushings are wore out, would this be the cause or is it more than that?
Old Jan 23, 2006 | 03:48 PM
4Cammer72's Avatar
4Cammer72
probably has a blown out shock too. raise the front end and give it all a good check.
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome biggman to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 23, 2006 | 04:24 PM
biggman70f100
ok. ill check that out to. thanks for the tip
Old Jan 23, 2006 | 05:42 PM
jrzoffroad's Avatar
jrzoffroad
The quick one to try is tire that is out of balance. If the tire is balanced, then swap it to the rear. If the vibration moves to the rear most likely the tire is out of round. A out of round tire can be balanced and usually a out of round tires shows up a the 40 to 55 mph range and then the vibration goes away. IF not either of those, front shocks, damaged broken coil spring and radius arn bushings are suspect.
Old Jan 25, 2006 | 09:25 PM
baitmaster's Avatar
baitmaster
Shock is bad for sure, I would replace them all. Cheap fix for a much better/safer ride. If you find its the tire, I would still do all of jzr's suggestions.
