Brake problem
Old Jan 23, 2006 | 02:36 PM
modeltford's Avatar
modeltford
Brake problem
I just replaced the front pads on wifes 91 Explorer with rear ABS. When compressing calipers so new pads would fit, I did it slowly, with a large c-clamp. Also adjusted the rear shoes - a bit too much slack. Everything worked fine Saturday and Sunday - took a 300 mile trip - but this morning, she tried to drive it to work, and came back complaining about having to pump the brakes up.
I checked everything out - no leaks, everything tight, fluid full in the master.
Sitting with engine running, first time you hit the brakes, pedal goes WAY down, but can then be pumped up with a couple hits. Same reaction driving it - once pumped up, it stops real well.
Any ideas - gotta get this thing working today!
Thanks!
Rich
Old Jan 23, 2006 | 08:44 PM
JerrySimm's Avatar
JerrySimm
Sounds like the master cylinder went out. You'll need to replace it. Probably just a coincidence with the timing. Be sure to bleed the new one when you put it in before connecting the lines.
Old Jan 23, 2006 | 09:52 PM
budman-mo's Avatar
budman-mo
The real question is does the pedal go to the floor and you then have no brakes?
IF it is just low but stops then I would re-check your rear adjustment.
huskyfan68
Sep 12, 2012 10:30 AM
evobuilder
Apr 22, 2012 09:56 PM
sublauxation
25
Aug 8, 2011 11:41 AM
