Which hi pressure lines to replace?
Old Jan 23, 2006 | 01:01 PM
Steve_250's Avatar
Steve_250
Dieselsite says this on the HPX page:
*We recommend these hoses, as well as the OEM high pressure hoses, to be replaced once a year. Many chips increase the duty cycle and length of the maximum pressures of the oil pump. This places exceptional stress on the hoses that they were not intended to see from the stock programs. The pressures in this system is very commonly at 3000 psi.
Ok, I know they are talking about the HPX and the ESOF, any others?
Old Jan 23, 2006 | 01:13 PM
PSNut's Avatar
PSNut
U gotta figure they're going to design in some headroom on what pressure the hoses are going to handle max. I haven't read any posts of someone who has had a HPOP line burst...just leaking crimp on rubber hosed Xline. Somebody will probably pipe in with a good story i'm sure.
Nut
Old Jan 23, 2006 | 01:16 PM
wlihntr's Avatar
wlihntr
there are talking about the lines that go from the HPOP (high pressure oil pump) to the heads. i dont know about replacing them every year but you should inspect them every so often (i take a look at them when ever i replace my fuel filter). the most common places they leak are at the ends. if you are going to do an HPX line you should look at the solid one form www.itpdiesel.com
Old Jan 23, 2006 | 01:57 PM
Kwikkordead's Avatar
Kwikkordead
Hmmmm, so how come the HPOP flex lines last nearly forever with an occational o-ring replacement.
Why can't they make them like that?
Old Jan 23, 2006 | 02:22 PM
Steve_250's Avatar
Steve_250
Ok, I'll pick up the solid hpx.
I think my esof being a pita is probably the hoses, I always step out and lock anyway. But whadd'a ya'll thing about their esof lines?
What other hi pressure lines are they talking about?
I mean geez, I'm not changing my hi press air cond line until it goes.
Old Jan 23, 2006 | 05:54 PM
jtharvey's Avatar
jtharvey
Brain fart...what's ESOF stand for??
Old Jan 23, 2006 | 05:55 PM
Steve_250's Avatar
Steve_250
The **** on the dash to shift into 4X4, Electronic Sometimes On Fly, er, I mean SHIFT on fly....
Old Jan 23, 2006 | 06:05 PM
jtharvey's Avatar
jtharvey
I didn't know the engagement of the 4x4 system relied on oil pressure. I thought it was an electroninc transfer case?
Old Jan 23, 2006 | 06:08 PM
Orezona's Avatar
Orezona
Dieselsite sells a replacement steel braded line for the rubber vacumm lines for the "auto" hub engagement.
Old Jan 23, 2006 | 06:10 PM
jtharvey's Avatar
jtharvey
Gotcha. Makes sense now. It has been a long day. Sorry to be off topic.
Old Jan 23, 2006 | 06:25 PM
Muktown's Avatar
Muktown
it is an electric transfer case with vacuum lines to operate the hubs. the lines always split and leak causing a vacuum leak and your pump to run constantly
Old Jan 23, 2006 | 07:24 PM
Steve_250's Avatar
Steve_250
It's called electrically activated, vacuum actuated.
AFAIK, it's an on-demand and your pump is running for other accessories anyway, like environmental controls.
