Sponsored by: Real Truck
Electrical problems
Old Jan 23, 2006 | 10:09 AM
cmwallace's Avatar
cmwallace
Electrical problems
I have a 2000 F2504x4 with 122000 mi. Great truck. I am having two electrical problems I need help with. 1)The alternator is putting out just over 13 amps and the battery is good under a load. Cleaned all terminals. Under a load (snow plow/ lights/heater) it is loosing charge. 2) Heater controls working in low and high only. Replaced resistor and control switch. What now? I am new to this forum any help will be appriciated. Thank you.
Old Jan 23, 2006 | 11:53 AM
99f350sd's Avatar
99f350sd
Welcome to the site!
If its the original battery then its prob toast. The alt with a good battery should be charging at 14.5 volts at the battery. A good battery should read 12.5 volts after the surface charge has wore off,lights on for 3 mins engine off. As far as the low and hi only you have a switch problem or a connection between the sw and resistor.
Dick
Wickedblockhead
Nov 20, 2009 10:06 AM
64F260
Feb 13, 2009 01:00 PM
sundayian
Jun 14, 2008 02:41 PM
fordbigtruck
1947 and Older Ford Trucks
Feb 4, 2002 02:55 PM
badboyina67
Jan 21, 2002 12:50 AM
