throttle body 4.0 sohc
Old Jan 23, 2006 | 08:44 AM
jeeping's Avatar
jeeping
What is the factory size of the throttle body and does anybody make a larger aftermarket one. I`ve searched and did`nt find much.
Old Jan 24, 2006 | 05:21 PM
wendell borror's Avatar
wendell borror
No, as far as i know, there's no aftermarket tb for the sohc. From everything I've heard, the stock tb is able to handle any aftermarket bolt on's, up to the explorer express supercharger. Your fine!
Old Jan 26, 2006 | 11:18 PM
devilsword's Avatar
devilsword
go to summit.com i was recently reading one of there catologs and they did make a larger bore tb for the 4.0
Old Jan 28, 2006 | 04:14 AM
wendell borror
SUMMIT does have a 66 mm for the 4.0, but it's for the ohv, not the sohc. I believe the stock tb on the sohc is 65 mm, if memory serves me right.
Old Jan 28, 2006 | 04:23 AM
wendell borror
Also forgot to mention, you can port and polish your stock tb for smoother air flow. 65 mm is pretty big on a v-6, unless you get some major head work and some radical cams, and such. With the 4.0 sohc in the new mustang, i am sure there will be all kinds of new goodies on the way.
