4x4 vs 2x4
Old Jan 22, 2006 | 11:01 PM
gator71's Avatar
gator71
4x4 vs 2x4
hi i got a 84 f150 4x4 and a 81 2wd. will the front end from the 4wd fit the 2wd.
Old Jan 22, 2006 | 11:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Jan 23, 2006 | 09:43 AM
oldhalftons's Avatar
oldhalftons
yes everything will swap over. 80-96 f150 is the easiest 4x4 conversion.
but the 82-up frames are much stronger than the 80-81 frames.
Old Jan 23, 2006 | 11:31 AM
69 and 85's Avatar
69 and 85
Front and rear axle ratios must match... might have switch out the rear end as well.
Old Jan 23, 2006 | 02:36 PM
slash31938's Avatar
slash31938
they dont HAVE to match if they are close and you keep it on soft ground, but if it is over probaly .50 or .25, and you want to drive it on the road then you will have problems. Me Thinks...
Old Jan 24, 2006 | 09:41 PM
wamullins's Avatar
wamullins
can i do the same swap with a 1980 F100 2wd and a 1984 f150 4wd?
Old Jan 25, 2006 | 12:08 AM
oldhalftons
yes you can.
ufvj217
Dec 20, 2010 03:12 PM
Duct Tape Racing
Aug 20, 2010 07:06 PM
njredneck
17
Dec 19, 2009 09:31 AM
HeaVEEweight
Jun 8, 2009 01:44 PM
