1978 - 1996 Big Bronco
3rd Brake Light Removal
Old Jan 22, 2006 | 09:53 PM
bradplock's Avatar
bradplock
I need to replace the bulbs in my 96 Bronco's 3rd brake light. After I take the 2 screws out, how does the assembly come out? Something seems to be holding it in. I can only pull it out about a 1/4 of an inch. What is holding it in?
Old Jan 22, 2006 | 11:54 PM
Chrisconsin's Avatar
Chrisconsin
pull harder, thats all it took to replace mine
Old Jan 23, 2006 | 05:32 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bradplock to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 27, 2006 | 05:20 PM
kumabronc's Avatar
kumabronc
I had the same problem. The left side of the light assembly did not want to slide out and for the life of me I could not figure what it was hanging upon. The culprit was a previous owner put in a higher wattage bulb than specified and the extra heat generated by the bulb melted the plastic of the light housing. When the housing melted the plastic bubbled up a little and kept the left side of the light assembly from sliding out of the pocket in the roof. I was able to get a bare hacksaw blade in there to shave off the melted spot and slid the light assembly out. Sorry but I do not recall the replacement bulb number and I can't get to my truck at the moment. I'll check when I get home.
Old Jan 27, 2006 | 10:28 PM
bradplock's Avatar
bradplock
that's EXACTLY what happened. the nimrod owner before me decided to use a higher wattage bulb and melted the crap out of it!!!
Old Jan 29, 2006 | 02:21 AM
greystreak92's Avatar
greystreak92
Swap to LED retrofit lamps and you will have the additional light output and a LOT less heat. You also won't have to replace them agian.
Old Jan 29, 2006 | 01:40 PM
bradplock's Avatar
bradplock
can anyone recommend a good place to purchase these LED retrofit lights?
Old Jan 29, 2006 | 02:07 PM
greystreak92
Check this site. http://www.superlumination.com/ They carry a wide variety of LED retrofits for all applications. The autmotive is the most complete line though.
Old Jan 30, 2006 | 04:59 PM
bradplock's Avatar
bradplock
awesome, thanks!!
