ATS Transmission
Old Jan 22, 2006 | 09:38 PM
MESTRKR's Avatar
MESTRKR
ATS Transmission
Hey all,
I just had an ATS tranny installed in my truck, I'm amazed with the improvement over stock..Its awesome to say the least. My only concern is when I put it in reverse or any forward gear the engine lugs down a bit. It is more noticable in reverse than any other gear. Today when the engine was cold, it really lugged down, probably around 100-150 rpm when put into reverse. It will usually lug down around 50-100 rpm when put in drive. Is this normal due to the new torque converter design, or should I take it in and have it looked at before it does any damange. Thanks for the help.
Ethan
Old Jan 22, 2006 | 10:14 PM
Fire Rooster's Avatar
Fire Rooster
I would take it in just to be safe but in reality bet it is the newer TQ
Old Jan 22, 2006 | 10:27 PM
wlihntr's Avatar
wlihntr
it is probably due to the TQ the usally put a lower stall unit in the hipo transmissions. i would still have it checked out to be sure. which level/stage did you get?
Old Jan 23, 2006 | 12:20 AM
MESTRKR's Avatar
MESTRKR
Its a stage 4. thanks for the replies...I'll have to find some time to get that done, ATS would probably know best but i thought i'd ask it here anyway. I'll let you guys know what i turn up.
E
