Sponsored by: Real Truck
Under dash wiring help
Old Jan 22, 2006 | 06:42 PM
rjmay's Avatar
rjmay
I am adding a rear camera to my PS 350 DRW CC LB so my daughter in law can drive the beast when not connected to their Airstream.
I am looking for a reverse wire and a parking light wire to tap into. This will activate the monitor and turn on the infrared LEDs respectively.
Can anyone help me find these under the dashboard?
Old Jan 22, 2006 | 09:33 PM
Reedtrn's Avatar
Reedtrn
The parking light wire is brown at the headlight switch. I cant be much help with the reverse wire though.
Old Jan 23, 2006 | 12:08 AM
swengle's Avatar
swengle
The reverse wire is black with a pink stripe, circuit 140. The easist place to get to it is at the Parking Aid Module (PAM) located behind the passenger door kickpanel, adjacent to where it meets the door. Pull the trim off, a couple of metal and plastic clips. There are several connectors there, you will find black/pink on C300 (pin 3) and C4014 (pin 3, for the PAM). C4014 is the one I used, very easy to tap onto. You won't find these designators on the connectors though.
I figured this out when I wired up my reverse camera (and a bunch of other stuff) when I replaced the radio with a DDX8017 from Kenwood. Eventually I'll post pictures of the entire install, it came together very well.
BTW: This was for a 2005 F-250 CC SB, I can't see the F-350 being different. Matter of fact it can't be, I bought Ford's "2005 F-250, 350, 450, 550 Super Duty Wiring Digrams" from Helm couple months ago. It's been my bible for all the electrical work I have done on the truck.
Steve
Old Jan 23, 2006 | 05:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Reedtrn to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
