oil leaks
Old Jan 22, 2006 | 06:42 PM
jeep1947's Avatar
jeep1947
oil leaks
got a 97 f250 leaks appear to be from rear main seal area. are there any other likely suspects. this is my first diesel and a have lots to learn about it. it has 193000 miles on it. was a one owner farm truck here in indiana. the previous owner kept it serviced reg. used all motocraft parts and fluids. since i have had it had to replace fuel pump.also changed valve cover gaskets and put new glow plugs in. going to change fluid in trans next week. any suggestions about things to do to keep her healthy will be appreciated.
Old Jan 22, 2006 | 08:04 PM
barebackjake's Avatar
barebackjake
check the valley of the motor to see if theres oil there. check the hpop plugs at the back of the heads also. i have never heard of a rear main leaking on a powerstroke. ive got 2 trucks with high mileage and havent had one leak either.
Old Jan 23, 2006 | 07:21 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts jeep1947. We're glad you've chosen the best site for Fords.
I agree with Jake. That "rear main" leak usually originates on the topside of these engines, and runs out the drainhole in the rear of the engine valley.
Old Jan 24, 2006 | 01:01 PM
jeep1947's Avatar
jeep1947
thanks guys for the tips will be taking her to my buddies heated garage tomorrow and check all of the above tips as well as trans fluid change. thanks again for the help jeep1947
