Modular V10 (6.8l)
Need ideas
Old Jan 22, 2006 | 10:58 AM
deanndeb's Avatar
deanndeb
whats causing this??
Hi. the info" 2003 F-550,4x4, V-10, w/whipple supercharger. The problem: Less than 3000 mi, Labor Day to be exact, pulling my 16,000 fifth wheel, I lost #4 and #5 cyl. Out of warranty, Ford refused to look at it cuz of the whipple, took it to a Hot Rod shop( good rep in the area I was in) and they found that the valves had "stretched". one was .14 and 1 was .19 longer than stock. Replaced and off I went, Of course 2200 dollars lighter in the pocket. Wendesday, hooked up to move to new job, less than 200 miles down tghe road, same thing!! only this time, 4,5,9,10 are out. Its in the ford house here(small N.C. town, seem to be good folks. So far no reasons as to why . The mech says the whipple couldnt do it, I only have 5-6 lbs of boost, but yet he doesnt know why. Any ideas? I would like to keep the truck, as it is set up now the way I want it. But, I have to have something dependable and the 10 just aint cuttin it. TIA
Old Jan 22, 2006 | 10:34 PM
T- Squared's Avatar
T- Squared
I guess it could happen, but it seems hard to believe the rpms these motors turn, even with chips and tuners, could do much to hurt the valves. I imagine you're running hotter combustion chamber temps than stock, but if high temps caused a problem with the valves you'd think the pistons and cylinder walls would be hosed as well. Did they show you the valves? Are they physically longer than new ones or did they measure the difference in deck heighth compared to the others? If the deck heighth was different, it's possible the valve seats somehow recessed into the head. But again, it's not like you're running anything terribly radical with single digit boost pressures.
Old Jan 23, 2006 | 10:21 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What valves? Intake or exhaust?
If it's the exhaust, sounds like a lot of backpressure and/or unburnt fuel overheating the valves and stretching them, although I would think the seats would be burned too. Like T-Squared said, were the valves really longer, or were the retainers worn or the valve seats recessed?
Maybe you have a bad run of valves? Hard to believe, but possible.
Again, which valves, intake or exhaust (or both) ???
How high are you running the revs?
fivonut
Ford Truck Parts for Sale
Jun 15, 2014 10:41 PM
'99 5.4L DUTY
Mar 6, 2014 09:02 AM
Ragger
2004 - 2008 F150
Aug 19, 2009 03:49 PM
F250Wildman
2004 - 2008 F150
Mar 22, 2005 07:47 PM
Ironmerganser
Modular V10 (6.8l)
Nov 22, 2002 02:43 PM
