Distributor wont budge...HELP!!
Old Aug 20, 2001 | 05:55 PM
NoPushrods's Avatar
NoPushrods
What's going on here, the thing wont turn or anything! I removed the bolt at the base of course but it ain't moving. i hosed the base down with plenty of WD-40, still nothing, any ideas on this one people?
Old Aug 20, 2001 | 06:03 PM
BB's Avatar
BB
A couple of ideas, try using carb. cleaner first.
https://www.ford-trucks.com/dcforum/61_79/5968.html
Old Aug 20, 2001 | 06:17 PM
NoPushrods's Avatar
NoPushrods
I tried the oil filter strap idea earlier, no dice. Guess I'll have to soak it for a few days and keep at it.
Old Aug 20, 2001 | 06:25 PM
whomrig's Avatar
whomrig
I had occasion to work on a similar problem. It was a 351C, and I used a small hammer and a drift, tapping (very carefully) to loosen it. Turns out, there was a lot of sludge build-up on it.
Wayne 60 F-350
e-mail
http://home.pacbell.net/whomrig
Old Aug 20, 2001 | 08:09 PM
kenmt's Avatar
kenmt
WD-40 is lousey for loosening anything-spray the dist.base with penetrating oil over a couple of days.FEs[360,390,]were notorious for this-I had to break one one time to get it out.
Old Aug 21, 2001 | 07:26 AM
Irondale90's Avatar
Irondale90
yep had the same problem with my 351M. I used penetrating oil, a good soak down for several days and finally came loose after I had the engine out and on a stand. Try not to break it. Or you can have a machine shop drill it out.
Old Aug 21, 2001 | 02:39 PM
buzzard's Avatar
buzzard
If it's an FE, get the biggest hammer you can handle and beat it like a red-headed stepchild.
Seriously, I had one that could only be removed by knocking it out from the bottom of the engine. If you do ruin it, they are very cheap to replace.
Old Aug 21, 2001 | 03:19 PM
KevinKos's Avatar
KevinKos
If you have the time let the penetrating oil work on it for a while if your in a hurry use a hammer and punch around the base. I ran into the same problem years ago and was able to knock it loose with a hammer and not damage it.
Kevin K.
Old Aug 21, 2001 | 08:48 PM
NoPushrods's Avatar
NoPushrods
I got it out finally. Carb cleaner spray, some gentle persuading back and forth with a hammer and a 2 x 4 on the tabs where the vacuum advance bolts on, along with some swift upward yanks on the intake since it was already loose, and it finally dislodged.
Old Aug 21, 2001 | 10:46 PM
anavet's Avatar
anavet
