351w plug wire seperation
Old Jan 21, 2006 | 05:13 PM
toolmantk's Avatar
toolmantk
Question 351w plug wire seperation
I searched the forum for this with no luck. I'm sure it has been discussed but I can't seem to find it. I remember reading about an issue with the firing order of a 351w and the arrangement of the plug wires in a certain way to prevent pre-ignition of a perticular cylinder. It was a situation where the energy from one plug wire was being transfered to another by induction and causing that cylinder to fire prematurely. I think the fix was to make sure the two wires in question crossed over each other at least once. I checked my Haynes manual but there was no mention of the problem. Anyone heard of this before?
Thanks
Old Jan 21, 2006 | 08:09 PM
Bdox's Avatar
Bdox
I'm certainly no 351 guru but if that is happening there is too much current flowing through those plug wires. What you are describing is exactly what makes an ignition coil work. Two wires running paralell to each other could certainly do that, but the fix would be to replace the wires. I have only seen this happen with metal conductors. The resistance wires, almost universally in use, limit the current flow so that they don't create radio interference, but have the side benefit of reducing cross induction.
This problem is soooo fifties!
Old Jan 21, 2006 | 08:37 PM
toolmantk's Avatar
toolmantk
From what I can remember this was a problem that was specific to the 351w and had to do with cylinders 6 and 5 because they fired one right after the other.
Old Jan 21, 2006 | 08:47 PM
Bdox's Avatar
Bdox
makes sense, a stray spark on the exhaust stroke (for example,) wouldn't notice.
70velle
Jun 2, 2004 12:05 AM
huckermatt
Aug 8, 2003 07:24 AM
bcarroll29
Aug 7, 2003 11:33 AM
Amenjephra
17
Nov 14, 2002 11:47 PM
concreteman
Jun 24, 2002 08:39 PM
