fuel filter
Old Jan 21, 2006 | 03:52 PM
altamm1977's Avatar
altamm1977
fuel filter
how in the heck do you get the fuel filter off of 98 explorer please helpwith any info possible. also truck is running rough while going down road almost like its wants to die kinda sputtering and what not any help please
Old Jan 21, 2006 | 08:37 PM
ssjrsw's Avatar
ssjrsw
You need a special AC/fuel line disconnect tool. The most common are in plastic but they are not always strong enough to diconnect the fuel filter. Parts stores sell a metal tool that looks like pliers. The size shoud be 5/16.
You slide this on the line into the fuel filter and it pushes the pins in to disconnect the filter. It helps to spray some WD-40 in first to clean out dirt andd loosen it.
Scott
Old Jan 22, 2006 | 07:37 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome altamm1977, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 22, 2006 | 11:28 AM
altamm1977's Avatar
altamm1977
ah i see thanks for the info ill have to check that out
Old Jan 22, 2006 | 06:55 PM
ssjrsw's Avatar
ssjrsw
Also don't forget eyewear the gas can spray out. You can pull the fuse for the fuel pump and crank the truck over first or depending on the model there is a valve to relieve pressure on the fuel rail. Normally left side of the motor up front. My 98 Explorer had no pressure after sitting overnight but not all are the same.
Old Jan 23, 2006 | 03:52 AM
altamm1977's Avatar
altamm1977
ok thx for info really appeciate it
Old Jan 23, 2006 | 04:08 AM
ford390gashog's Avatar
ford390gashog
summit sells the tool and so do parts stores. summit sells the real good metal tool the parts stores sell the pastic ones which are hit or miss and a lot of frustration.
