Leaky rear end
Old Aug 22, 2001 | 10:19 AM
sweetpea's Avatar
sweetpea
Leaky rear end
Got a 70 F250 2wd and I noticed today that it is leaking from the front of the rear end. Easy to fix? Just the seal? Drop the drive line, dig out the seal and replace? Any advice is appreciated.
Thanks
(also posted to alt.ford.trucks)
Old Aug 22, 2001 | 11:27 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Leaky rear end
Is it leaking between the axle housing and the removable center section (pumpkin), or at the front of the center section where the drive shaft connects?
Old Aug 22, 2001 | 03:36 PM
Nathan's Avatar
Nathan
Leaky rear end
Check and see if the housing vent is plugged before doing any time consuming repairs.
Nathan
Old Aug 22, 2001 | 10:38 PM
sweetpea's Avatar
sweetpea
Leaky rear end
Yes it appears to be leaking at the front where the drive line hooks up. I'll also check the vent. Thanks a ton! I went and bought a new seal and rear gasket anyway.
Old Aug 23, 2001 | 10:08 AM
buzzard's Avatar
buzzard
Leaky rear end
Both the seal and gasket are very easy to replace. The hard part is torquing the pinion nut to ~250ftlbs. While you're back there, you ought to put a new vent tube on as well.
Old Aug 23, 2001 | 11:15 AM
bigf150's Avatar
bigf150
Leaky rear end
to change the gasket you gotta take out the center section to do that you just gotta pull out the axles theres 4 nuts to take off the backing plate for the axles then unbolt the center section and pull it out
Anthony DiPietro
79 F150 Ranger
Old Aug 23, 2001 | 03:09 PM
jwtimme's Avatar
jwtimme
Leaky rear end
