sick 97
Old Jan 21, 2006 | 02:15 PM
Brucelammes's Avatar
Brucelammes
sick 97
I have a sick SUV. It has several problems. First off the check engine light came on and then it started skipping. I was wondering if someone can tell me where the spark plugs are? I cannot find the traditional type wires to follow. I thought I would stop by replacing them. The truck has 105,000 miles on it of which I have put 25,000 on it since I bought it and I have no idea how old the plugs are. Second, the air suspension pump does not always work. The truck was in wreck where it went over a Corsica and had front susupension damage. The compressor has given me intermitent problems since. The body shop was no help because the pump was working at the time they looked at it. Third, the rear AC does not work. The fan works fine and the AC lines running into it are real cold. IS there a temp censor that could be the problem? I noticed some sort of electrical companent that was in the duct. The fourth problem is the manifold exhaust leak that I think this forum can't help with. Any ideas?
Old Jan 21, 2006 | 03:31 PM
skier-24's Avatar
skier-24
What are the codes? Autozone reads them free.
Spark plugs are under their individual coilpack. No wires.
Check all wiring for compressor. You may have a loose wire causing an intermittent problem.
